visa open & visa configure serial port.vi
I read the help file, it said <visa open.vi> open a new session.  I wonder is the vi <visa configure serial port.vi> can replace <visa open.vi>?
that is, is the visa configure serial port.vi inlcude the function of visa open.vi ?
(6,925 Views)
You can double click on Serial configure to see what it contains.
VISA open is not actually necessary.  Any of the VISA functions will automatically open the serial port.  The serial configure doesn't contain an explicit VISA Open, but it does open the serial port.
(6,919 Views)
One additional piece of information: VISA Open isn't actually necessary now. It used to be that you needed to use it. I don't really remember at what point the automatic opening got put in. The function is still there so that older code won't show up as broken when opening in newer versions of LabVIEW.
(6,916 Views)
I'm not sure how it handles TCP connectios though. I always feel more comfortable using an explicit open when dealing with network connections. I realize the OP was discussing serial connections however since we are talking VISA, other connection types should be considered. After all, that was the whole purpose of VISA, to allow the connection to be agnostic with respect to the connection type.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(6,913 Views)
It does the same thing for TCP connections.
(6,898 Views)
I still prefer explicit open/close rather than implicit.
Mark Yedinak
LabVIEW Champion
(6,890 Views)
