10-15-2012 03:09 PM - edited 10-15-2012 03:10 PM
The LabVIEW "trick" is usually to get the hardware settings correct. Have you tried "Hyperterminal" to talk to the unit. It is possible that the software supplied by the instrument manufacturer uses odd "end of transmission" chars or something like that.
It is a good idea to start a new thread when you have a problem rather than hijacking over a year old. Someone opening this one might never get down to your question.
10-15-2012 03:47 PM
The command should work. Just make sure that all serial parameters are correct.
10-15-2012 03:49 PM
How do you implement the carriage return and line feed?
10-15-2012 03:50 PM
Thanks, for the suggestion. I will check.
Sorry about hijacking this message. This is the only reference to labview support for Paroscientific transducers I can find on the internet.
10-15-2012 10:12 PM
For this command, I dont have carriage return or line feed. I can put a screenshot tomorrow.
