visa read problem
Hello!!
I made a program that reads data from an Arduino microprocessor. Once I realize the exe and connect Arduino, the program starts reading the data, but only for a few minutes ... then it stops and i have to disconnect and reconnect Arduino....any ideas?
Thanks a lot!
(2,850 Views)
Hi
when you disconnect your arduino, do you turn off the power? If yes, it may be a memory issue in your arduino. I've worked once with Arduino, and we had an issue with data stacking over and over in the arduino
Giuliano Franchetto
Student at the l'Ecole Nationale Supérieure des Mines de Saint-Etienne, cycle ISMIN (FRANCE)
(2,840 Views)
Solved, there was an other problem in the program that was causing crash.
GM
(2,810 Views)
