visa resource control not finding any devices
I have an appliction that uses some VISA drivers to communicate with a Xantrex power supply.  I wrote the app a while a go and it works fine on the machine that I orignally installed it on.  Now I want to run it from another machine, but it can't find any devices.  Usually, the VISA resource control shows a drop down box listing all of the devices, but on this machine it won't drop down.  When I go into Measurement and Automation, I get the error "No VISA resources found."  I know that the code itself works, but there is just some part of the VISA driver that I am missing.  I downloaded NI-VISA, but when I install it, it inspects my configuration and says that everything is already installed.  I must have installed something on the other machine that isn't installed here, I just can't figure out what.  Any help would be great.
(3,397 Views)
What type of connection do you have to the instrument? GPIB or serial? What shows up in MAX?
Message Edited by Dennis Knutson on 09-11-2008 08:27 PM
(3,392 Views)
I have an NI pcmcia GBIP card.  When I go into Measurement and Automation Explorer (is that MAX?) it sees both power supplies, but below it there is an exclamation "No VISA resources found."  When I click on the "Instrument 0," and go the VISA properties tab, it shows the name of the device GPIB0::12::INSTR.  Is there something that I need to register to make the VISA work??? I was reading somewhere about an ini file.  I also found the Driver Wizard, but I don't know any of the parameters that it is asking for.
(3,334 Views)
Unless you are using IVI drivers, you should only need to have NI-VISA and NI-488 installed. What versions of MAX, NI-VISA, and NI-448 do you have installed? Have you tried uninstalling what you have and doing a fresh install?
(3,323 Views)
