visa run time
We want to deploy an exe version of VI to a customer already using the RTE for LV2011 on win XP.  The new application uses VISA.  It looks like the application can't find the drivers (error -1073807202).  Should I conclude that the LV RTE does not include the Visa drivers and that the customer should install them seperately ?  Which version is to be used ?  5.0.3 is the most recent version for Win XP but only supports LV2010.
(2,598 Views)
Yes. This is a question that has been asked many times.
Preferably the same version you have installed, since you developed the application using VISA. So what do you have installed? Open MAX and see what it shows you in the list of installed software.
The most recent version is 5.1.2, and it supports XP and LabVIEW 2011.
(2,593 Views)
