visa serial read hex
I am using labVIEW 7, and cannot figure out how to configure VISA read to output HEX instead of ASCII. I am able to read from the serial port, however I am having to do a conversion from ascii to hex. I was unable to find a direct conversion from ASCII to hex so several steps are used. Can someone tell me if it is possible to read hex directly from a serial port, or if there is a good way to convert from ascii to hex?
Thanks for your help,
Jesse
(5,009 Views)
Hi Jesse,
This is a little subtle but bear with me.
When you read from the serial port and get a string, you ARE READING HEX!
I am guessing what you really want is an array of bytes that you can act on directly.
Wether it is an array of bytes or a string the data is the same. What is different is the representation.
The "type cast" (found on the advanced >>> data manipulation pallette) will let you change the represenation of your data.
You wire the data you want to change the representation of to the left input and a "type" into the top input. The "type" just tells LV what representation you want.
So...
drop a "type cast" on your diagram and wire the string to the left input. Wire a byte array to the top, and you are now free to work with t
he bytes using any number system you want (including HEX).
I hope this help,
Ben
(5,009 Views)
There are also "String to Byte Array" and "Byte Array to String" functions that do this.
Type Cast can also be used if you have 16- or 32-bit data. Just wire in an array of i16's or i32's to the type input.
Brian
(5,009 Views)
0jd wrote in news:50650000000800000078DD0000-
1079395200000@exchange.ni.com:
> hex?
Could you use the "String to byte array" function?
Function palette->Numeric->Conversion
or (same function)
Function palette->String->String/Array/Path Conversion
Rolf
(5,009 Views)
