visa wiht png images
HI,
I have a vi taht reads bytes via RS232 with 25 draw ovals. When I run the VIit hasa hugedelay and most of the time is freezes.
(2,766 Views)
You are blocking the important things for the VISA communications.  But here are the things for the VISA configuration:
1. Make sure the Termination Character is turned OFF.  That could cause some weird things for you if one of the data bytes happene to match the termination character.
2. Change the Byte Count to a constant and make sure it is set to 3.
3. Make sure the rest of your serial port settings are currect for whatever is sending you the data.
Is the data constantly being sent out?  Or is it only sent out on a command?
GCentral
(2,760 Views)
Hi Crossrulz,
thanks for your reply. Yes, the data is continiously being sent to labview via RS232. everything works fine when I use booleans (Led's) assigned to each bit in a byte. the problem only occurs when I use the 'draw oval' vi's. Seeing from highlighted execution, I assumed it has some thing to do with timing.
(2,732 Views)
