visible front panel?
Greetings,
I'm a LabView 'newbee' and I have a basic question.  How do I make a VI's front panel invisible?  I have one main VI which implemates and controls a state machine (simple mediator pattern), but I do not want the front panel of the main VI to be visible.  I saw one example where one VI controlled another VI, but not the VI controlling itself ('this instance' reference?).  Any suggestions would very appreciated.
JMA
(3,343 Views)
Try this
(3,315 Views)
Greetings Elsa,
Thanks for the quick response.  Unfortunately, I do not have LV 8.0 installed.  Any chance or recompiling for 7.1?  Thanks.
JMA
(3,307 Views)
When you run it, make sure you open the block diagram too, that way you can use the abort button to kill the VI
(3,294 Views)
Greetings Elsa,
Thanks for recompiling the VI.  I get 'Property Node: invalid property' when I open the VI (all three nodes invalid).  Any ideas?  Transparently appears to only be a subpanel property.  I do not even know how to create this node.  What should the steps be to create invisible? (VI launches, reference to intself?, set run transparently true)
JMA
(3,280 Views)
In LabVIEW 7.1 you can use the "state" property of a front panel window to hide it.
But whether or not this is a sensible thing to do for your application is another matter.
Message Edited by MIG on 03-09-2006 02:09 PM
(3,268 Views)
Thanks MIG.  Sensible does not seem to always follow necessity 😉  The VI I would like to hide is my main VI which dispatches/organizes all tasks.
Cheers,
JMA
(3,254 Views)
