vision Assistance old version
I am trying  to find an old Vision Assistance for Labview 2014 .
(1,871 Views)
Hi Benny,
if you are referring to the Vision Assistant Express VI, in order to use it you need the Vision Development Module. You can download it from here, the 2014 SP1 version should be fine. For more information, you can refer to this document.
Hope this helps!
Alessia
(1,810 Views)
Hi Alessia
The download is  available only to customers with SSP membership that I don't have .
Benny
(1,770 Views)
Hi Benny,
in case you purchased a software license some time ago, you are still entitled to access the versions included in the license, even if the SSP is no longer active.
To get the software you need, I suggest you open a service request; the NI technical support service will take charge of it.
Alessia
(1,751 Views)
