vision assistant STRING OUTPUT
I just want to compare two strings . One from the string constant given by the user and the other from the vision assistant. Used equal comparator but its shows fail even for true conditions ..
(3,255 Views)
Maybe you need to use the "Trim White Space" from the string palette???
Show some code if this doesn't help.
Glad to answer questions. Thanks for any KUDOS or marked solutions 😉
(3,244 Views)
I Tried trim white space but no solution..
Here i attached my program
(3,232 Views)
Ok, I'm sorry to say that I don't have the vision module, but the code you posted has no comparison going on. Post some code of the comparison that doesn't work.
(3,213 Views)
