vision builder brightness adjustment
Is there a way in Vision Builder to adjust the brightness and contrast so that a defined bright spot in all images is equalized,
and, at the same time, a defined dark spot is also equalized?
I am trying to do a caliper measurement on an edge that doesn't have a well define transition and the measurement changes
with the light intensity.
(3,152 Views)
Greetings,
I guess you could use the property nodes of the IMAQ to set your exposure , brightness.
I have used them some some time back.
Sundar.
(3,145 Views)
Hello inko,
In Vision Builder, there are a few edge detection filters that would help you with the caliper measurement. In the Inspection Steps palette, under 'Enhance Images', there are a couple of options that could be useful to you.
The 'Filter Image' step has edge detection filters to choose from, that would make it easier to define transitions at the edges. The 'Threshold Image' step would enable you to distinguish between bright and dark portions of the image according to a threshold value that you can set. It might be a bit tricky to use the threshold step, as it cannot detect both the dark and bright spots at the same time.
I hope this helps! If this does not answer your question, could you post a sample image in your next post to help me understand your issue further?
Vivek Nath
Machine Vision
(3,132 Views)
