visualize array values on graph
I may have missed something in the earlier replies, but would an intensity chart give you what you're looking for?
Ian
Message 21 of 26
(1,724 Views)
Great idea - that could be the way to go.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 22 of 26
(1,717 Views)
What do you mean by Intensity chart ? What is it ?
Message 23 of 26
(1,711 Views)
If you go to Help/Find Examples and do a search for 'intensity' you will find some examples there. They should explain it better than I would be able to. But essentially it is for plotting a 2D array onto a chart or graph where the value at each element from the array is displayed as a colour, as the value changes so does the colour.
Ian
Message 24 of 26
(1,706 Views)
Yes, I went there before, but this affects a color to a value which is in the array but in my example, I wouldlike to affetc a color for a specific XY point related to a value.
For example for the point Az-20 El-30, if the offset is 40 I display the red color (because between 30 and 60 that corresponds to the red color).
Message 25 of 26
(1,696 Views)
I have trouble to display multiple curves in one XY graph through a loop.I would like to display a curve of different colour at each iteration of the loop, as shown in the file attached.
Thanks for your help.
Message 26 of 26
(1,667 Views)
