vnc stops labview exe
Windows XP OS.
I developed one labview application which basically reads data from one Arinc 708 (avionic) interface and writes them down to disk.
If I connect to the PC via VNC while the application is running and I do several times things like: reduce to icon and enlarge, the application stops writing data. It does not crash and you can still close it using the windows x icon. It goes in a kind of 'idle' state.
I also changed task priority (from normal to real time), things get better but the problem is still there.
Any suggestion?
Pier
(2,946 Views)
Hi Pier,
I tried a couple of LV apps using Ultra VNC 1.0.2 but couldn't find any issues. Could you please specify what version of VNC you're using. Secondly, I was wondering why you are using VNC to access the VI. If you're just interested in accessing the front panel of the application you could use LabVIEW web server.
Nitin
(2,919 Views)
I use Tightvnc 1.3.9 without any problems.
(2,903 Views)
