voice compression
I am working on UDP voice sender/rec and used it on network it is working good but i want to reduce bandwidth (present BW: 180 kbps meseared on wireshark) over channel to 32/64 kbps. please help me to do it.
Message 1 of 13
(5,466 Views)
Hi prashantece,
at which university are you studying?
What kind of help do you need?
- When you want to have a programming job done you may advertize it in the "job offerings" forum.
- When you need help on specific problems you should attach your VI and pin-point the problem, some good example data preferred…
- When you need general ideas on your question topic you may read a good book or look up Wikipedia! You may look for abbreviations like FLAC, MP3, OPUS, AAC, CELT, SILK…
Message 2 of 13
(5,456 Views)
You can ofcourse change sampling parameters to 8-bit and 11kHz sampling, you can zip the stream before sending it, or use some compressed sound format. What are you doing now?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 13
(5,436 Views)
here i attched my vi
nd i want to make a voice transmission system using udp protocol.
Message 4 of 13
(5,429 Views)
at the given combination (8bit and 11k) there is very poor quality of audio(like donald duck) is coming so any other idea.....
regards
Message 5 of 13
(5,428 Views)
Is it meant for spoken word or music? 8bit 11 khz is slightly better then a cell phone.
Qestit Systems
Message 6 of 13
(5,406 Views)
If it is speak, you only need mono.
Qestit Systems
Message 7 of 13
(5,404 Views)
Hi prasha,
present BW: 180 kbps meseared on wireshark over channel to 32/64 kbps
 Well, right now you need a BW of [stereo, 16bit, 11,025kHz] 2×11025×8 = 176,4kbps.
To reach your goal of 48kbps you should use [mono, 8bit, 6000Hz] settings: 1×6000×8=48kbps.
When it comes to "listening quality" (which is not mentioned in your first post!) you really should read literature on the abbrevations mentioned above…
Message 8 of 13
(5,388 Views)
regards
In the VI you posted you're using the wrong output from the grab sound.
Qestit Systems
Message 9 of 13
(5,357 Views)
Hi, prashantece,
Do you want just to resample your voice data?
Message 10 of 13
(5,346 Views)
