voltage amplitudes changes depending on sampling frequency (NI-9234)
I have a qeustion about NI-9234 (vibration module). I connected one accelerometer (PCB 393B31) to this module and made a just simple code with Labview 2019.
The problem is the voltage amplitude is changing depending on how I set the sampling frequency (Signal lengths are the same).
The below screenshot shows the signal when I set a high sampling frequency (25.6 kHz).
The below screenshot shows the signal when I set a low sampling frequency (17 kHz).
As you can see, the amplitudes are different in the time-domain signals.
The accelerometer is attached to a bridge.
In the Labview, I set AC coupling, Pseudodiffferential mode.
I am not sure why the amplitude is changing by the sampling frequency.
(1,272 Views)
If your screen shots are real, the lower frequency sampling rate is 1706.67, not even close to 17kHz. I think I would need to see the vi to go further than that.
(1,240 Views)
