voltage and temperature read at the same time
I'm using DAQmax to read 2 channel voltage and 1 change temperature continuelly, each of them work well, but I don't know how to make them at the same time, attached the file, thanks ahead.
(2,596 Views)
Thank you for contacting National Instruments.
I modified your VI. See if it works correctly now. Keep in mind that you can select more than one channel for a particular task by selecting Browse in the channel constant and holding the control key while selecting multiple channels.
I hope this helps!
Matthew C
(2,596 Views)
