voltage output gain
I’m generating a voltage output (0-10v) to simulate a temp range from 0-100deg c. The external 3rd party controller normally accepts a 0-10v signal, and displays its temperature reading proportional to its voltage input, i.e. 1v should equal 10 degs. When i inject 1v into the controller from the daq, it reads near enough 10 deg (just slightly over) , however, as i increase this voltage, an error starts to grow at each ten of degrees, almost like its needing a gain adjustment.
I noticed that the external controller does have a gain and offset pot just before its own ADC. My question is, should i be trying to use that to trim the signal, or could i create an artificial gain an offset in labview to compensate?
Many thanks
(2,318 Views)
Do you measure the corect voltage at the out put of your DAQ before the third party device?
Alan
(2,313 Views)
