voltmeter vi
I have made a voltmeter.vi in LV 6.0. I am using it to measure a 5V dc signal. I am using a NI-6025E DAQ card. However my dc signal varies between 4 and 6 volts. My analog voltmeter reads 5V. However the readings on the digital scale on my front panel changes wildly between 4 and 6 volts. How do I get the digital scale to read like my analog voltmeter? I suppose I must take 100 readings and divide by 100. How do I do that? The vi is attached.
(5,532 Views)
All that you have to do is wire the waveform output from the acquisition into the Mean function (Analyze>Mathematics>Statistics palette). You should already know that you're taking 1000 samples and how to change that to a lower or bigger number.
(5,523 Views)
Hi labview1958,
      You're probably way past this now. but if not...
It might be good to understand the difference between the DMM and the values seen on your VI's FP.  I'd double-check that wiring and AI signal-reference settings (differential, RSE, NRSE) agree, and certainly look at the signal with a real (not virtual) oscilloscope - if one's available.
       I take it you were reading single voltage values(?) If so, look to the LabVIEW Examples for "multi-point" (AKA "waveform") acquisitions.  Dennis Knutson's directions will get you home.
Cheers.
When they give imbeciles handicap-parking, I won't have so far to walk!
(5,489 Views)
As Dynamik mentions, if you can put an oscilloscope on the signal, or even look at the waveform in Meas & Automation (MAX) it would be a good idea. It sounds like you have a lot of noise or ripple on your signal. 2 V p-p is a fairly large amount. Most DMM's in DC mode, automatically average the readings (which can cause other problems when it would be good to know that the signal/voltage is varying relatively rapidly) so that what you are reading with this kind of "signal" is the mean of the ripple + the DC component. Performing the avaraging (connecting to the MEAN function vi) will help, but I would still want to know what I am actually reading, which is why I too suggest the scope/MAX view.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(5,464 Views)
