vxlapi LIN
How to transmit a LIN message(ID and 8 bytes data) via Vector interface to the ECU?
 I cannot find a function able to send data.
Message 1 of 40
(8,684 Views)
hamidnaghi1234,
What hardware and software are you using?
Have you taken a look at the LabVIEW XNET Lin examples?
Will M.
Message 2 of 40
(8,653 Views)
It's LIN CancaseXL interface from Vector company.
Message 3 of 40
(8,644 Views)
Have a look at the vxlapi.dll wrapper VIs and examples in this NI community document here.
Vector XL Driver - LabVIEW wrappers
https://decibel.ni.com/content/docs/DOC-30180
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 4 of 40
(8,636 Views)
Sorry, site went down for maintenance before I could add to my response.
There is an example of simulating a LIN network in the document. Starting with that example you can modify it so that the master node responds to its own xlLinSendRequest() thus sending ID and 8 bytes of data.
Message 5 of 40
(8,625 Views)
I set one config value for both Slave and Master, I didn't recieve any data on the Monitoring table.
Message 6 of 40
(8,600 Views)
I can't speak much into the how the application should respond here as I'm not familiar with the library on the community page. Did you make any modifications to the examples?
Will M.
Message 7 of 40
(8,573 Views)
Is the CANcase LIN channel actually connected to a slave?
Does the Master node have a properly configured pull-up?
Do the CANcase LEDs come on when you transmit? What color? Red or green?
PS. Sorry for slow response. I've been on holiday Smiley Happy
Message 8 of 40
(8,132 Views)
You're in luck. I have a requirement to communicate with LIN slaves with LabVIEW as the LIN master sending data to the LIN slaves.
So I have been able to spend the time to modify the "Simulate LIN network.vi" to demonstrate how to do this.
There is now also a "Simulate LIN network -master transmit.vi" which allows you to transmit data from a Master to Slaves.
Remember that a master node MUST HAVE A PULL-UP!
The VI control defaults will try to configure 2 LIN channels. One as a master, one as a slave responding to 4 IDs. The master will also send out it's data that the slaves can receive.
Link to document containing example VI
By modifying the default control values on the front panel you can change it so that only the Master node is configured and it sends data out it's own channel with no slave connected or configured. (See front panel below for this configuration.)
Message 9 of 40
(8,087 Views)
Thank you so much Troy. I really appreciated it.
Hamid
Message 10 of 40
(8,063 Views)
