waituntil alternative in LabVIEW
Yeah adding a shift register should work with that.
Message 21 of 29
(1,669 Views)
Dear Dennis
Thanks for your help, is it very much appreciated
Message 22 of 29
(1,650 Views)
Dear napview
Thanks alot for your help, what is the icon name  that makes rid of left over byte from previous run?
Maple...
Message 23 of 29
(1,644 Views)
Dear napview
dont I need to flush the contents of the buffer before I read also ,
Thanks...
maple
Message 24 of 29
(1,640 Views)
Not really since you only do that once before the loop so anything after that is valid. You only do that more than once if getting out of the loop and do the same or a different write/read operation but usually a few bytes do not affect much. The serial port works best if you have some handshaking scheme like looking for a distinct checksum for each write or read.
Message 25 of 29
(1,632 Views)
The flush buffer icon is under diagram function pallete/instruments IO/serials/. Just add this VISA flush pallete to the Dennis approach should also work too.
Message 26 of 29
(1,630 Views)
Thanks alot for napview and Dennis for you help, I attach an VI program that writes the ASCII character "A" waits till an ASCII character "B" from the serial port , Thanks alot for your help guys
Message 27 of 29
(1,620 Views)
It looks ok but the write should be inside the loop: logic is keep writing until a B is read and get out of the loop to do something else. Also there is no need to flush it after the write because this could get rid of that important B character from the device. Your logic might be the A character is still in the buffer but that would not affect anything coming from the device. But does this vi always work? If not try what has been suggested.
Message 28 of 29
(1,607 Views)
Hi napview,
Thanks  alot  for your post, and thnaks for all of your help
Maple
Message 29 of 29
(1,593 Views)
