wanted to handle event structre of the front panel in back ground dataprocessing
i wanted to handle graphs , selecting in it adding signals to it dynamically to it and also adding new graphs in front panel dynamically in parallel to data processing (i.e, data reading , data processing and data writing to external hardware in one loop.
so i kindly need suggestion for it
thanking all
sampath
(2,539 Views)
Which hardware are you using? You can update the graph by using a property node inside the same loop where you acquire the data.
(2,535 Views)
Muks handeld the adding plots to graphs part.
You can use sub-panels to display sub-VI screens or spawn additional FP that show your graphs.
Ben
(2,517 Views)
