warner/superior electric's SS2000PCi motion controller interfacing with LabVIEW 6i
Sir,
In our application, we are controlling the movement of X-Y arm on the X-Y table. For this we are using superior electric products:
(a) Slo-Syn SS2000PCi Programmable Step Motor Controller
(b) MD808 Motor Drive
We are using two such controllers and motor drives to drive two 2 Amps Sanyo Denki Stepper motors: one each along X-axis and Y-axis. Along with the arm movement a data acquisition also has to be carried out. So, the motion control and Data Acquisition has to be synchronized by means of software. The problem now is to program the controller. Though MCPI Version 4.41 is there, we want to program the controller in LabVIEW 6i so that we can synch
ronize both motion control and Data Acquisition.There is no driver which is compatible to LabVIEW 6i.
Is there any 32-bit DLLs for this controller? If any one has these dll's please let me know. My E-mail ID: nagendra_mg@yahoo.com.
So that i can call these DLLs in LabVIEW 6i and program it.Or else send me at least the detailed low level command sets of the controller in pdf format so that i can develop our own drivers.
Nagendra
(3,257 Views)
Nagendra,
Unfortunately, I was unable to find any helpful resources for you based on a cursory web search. I recommend that you contact the manufacturer of the hardware and ask them if they have a driver (DLL) that you can use to interface with LabVIEW.
Good luck with your application, and have a good day.
Sincerely,
Darren N.
NI Applications Engineer
(3,257 Views)
