Hi John
Can´t run your vi. Missing wav to waveform.vi. but never mind!
You are rigth, NI wav read vi reads all waveform at once and this is a trouble if wav file is long.
See attached vi (7.0). It reads Wav header and allows you to read data using standard NI read vi´s.
Wire audio index to Start of read offset of "read from I16 file vi" (if 16 bits audio) and read the chunk of data you want to.
Don´t forget to use "swap bytes" to convert data.
I use a while loop to read and process chunks of audio data from very long audio files.
Hope it helps.
Post back if some doubt.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
