wave form graph and remote front panel
I have developed an application that uses remote front panel to publish the VI on internet.I  have used wave form graph in my application . i tested it on the same PC where my labview server is installed. in my VI  select some data from a file and draws graph on wave form graph conttrol.It works fine if i use this from web browser ruunning on same PC where labview server is installed. on other pc at my LAN i installed Labview run time engine and tried to access the same VI using web browser. but now it does not draw graph. mind it iam using labview wave form graph to draw the graph. what could be the possible reason.
(2,642 Views)
veify how many remote users does your license manager support.
(2,639 Views)
it support enough client.in fact the other VI iam using run fine that VI is acquiring data in real time and plotting graph on wabe form graph . it works fine there but when i dra gaph on wave form graph using  data array in other VI it does not show any graph on the remote client web browser.
(2,633 Views)
Hi Dost,
Can you send me LabVIEW VI that you are trying to publish on the internet so that I can further look into the problem you are having?
Emma R
NIUK & Ireland
(2,604 Views)
