wave measurment virtualbench
I would like to use a virtualbench to aquire data from a laser vibrometer.
The problem is that i can't figure out how to put those measured amplitudes in an array.
(2,895 Views)
Are you using the DMM or the oscilloscope part of the Virtual Bench?  If the DMM, then do a read inside of a FOR loop and autoindex the values.  If the oscilloscope, the read gives you a waveform.
(2,864 Views)
