waveform calcul frequency
I want calculate the frequency of a waveform captured.
But I have Labview base, so I haven't VI signal process.
How calculate the frequency of my waveform ?
Do you have a VI for that ?
Thank in advance.
Seb
(3,087 Views)
Hi Seb,
Unfortunately LabVIEW base does not contain the functionality to calculate the frequency, the following knowledge based article details the limitations of LabVIEW base.
http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/08ea09e507da8246862571ed005c99eb?OpenDocument
Kind Regards
Ben L
Field Engineer
(3,081 Views)
Seb,
depending on the resolution needed, here is an idea that might work (not tested):
-calc the mean of your signal and subtract the offset (if there is some)
now basically determine the zero crossing, measure the time intervals between positive(negative) slopes and you can calculate the frequency
take more periods to increase resolution
bandpass your signal in the region of interest, analog or digital (a 'slow' basic digital filter can be written in a for loop with shift registers)
Message Edited by Henrik Volkers on 10-07-2008 03:34 PM
Greetings from Germany
Henrik
LV since v3.1
(3,060 Views)
