waveform chart gaps
When i'm thinking on it... I control a laser with those square waves. I make a waveform with a graph and do an interpolation to make a generation file with a sample frequency of 1024 Hz. So sometimes there is 0 time between a jump from 2 volts to -1 volt for example. But then again the chart should interpolate also. But maybe not...? Thanks for all the thinking! Happy easter everyone.
Message 11 of 25
(2,115 Views)
Have you tried zooming in on the broken parts of the graph to see if it is really a discontinuity?  Does the graphed data reflect the discontinuity?
Bill
CLD
(Mid-Level minion.)
Message 12 of 25
(2,093 Views)
It's a chart, not a graph...
Message 13 of 25
(2,085 Views)
Okay, I stand corrected.  But can you do those things?
Bill
CLD
(Mid-Level minion.)
Message 14 of 25
(2,079 Views)
Well the strange thing is, when i stop the program the gaps are filled with a straight line... I have to try the zooming at work.
Message 15 of 25
(2,073 Views)
Sounds more like a rendering issue than a data issue.  Maybe something simple like resizing the chart in the horizontal direction will help?
Bill
CLD
(Mid-Level minion.)
Message 16 of 25
(2,068 Views)
Hello Thijs,
Is it possible to create some test code that should allow me to reproduce this behavior locally?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 17 of 25
(2,054 Views)
I am trying to give some test code, but my program is rather big, 319 VI's in total now... So thats alot of work. The acquisition is in a seperate loop, with a message handler queue mechanism like the example given in LabVIEW. But i already made this some time ago with another application and then there weren't gaps...?
Thijs
Message 18 of 25
(2,048 Views)
Hello Thijs,
I fully understand that you are not able to share the full code.
However, are you able this behavior with a limited subset of your code?
If I can reproduce it, then I can focus better on finding a way to resolve it.
Kind Regards,
Message 19 of 25
(2,039 Views)
Here is the whole program; https://www.dropbox.com/sh/chlhwh0ox6tmmsc/Vro5S_z9P6
1. change the acquisition and generation hardware in the ini file.
2. make 2 folders on your c drive:
C:/eyemovements/subjects
C:/eyemovementsbackup/subjects
3. i also use the open G library...
Run the 'Main' vi from the project, create a subject, make a new measurement and then you see what i mean...
Good luck!
Thijs
PS. this is still very beta...
Message 20 of 25
(2,032 Views)
