waveform chart: grid style and color don't work?
Hi
I am trying to show vertical grids with my chart. What I do is to right-click the chart and change the property:
But I unfortunately didn't get the expected result (the lower chart):
Does anyone know what the problem is?
Thanks a lot!
(5,782 Views)
It seems you have only modified it for X-Axis, do the same for Y-Axis..
(5,776 Views)
No I did the same to Y axis. As you can see the horizontal green grid is from the setting of Y axie. Only x axis's setting didn't work.
(5,755 Views)
Hi funin,
You may try ticking the Autoscale option for the Y-axis. This must be causing the problem. For better solutions kindly upload your vi.
Nitzz
(Give kudos to good Answers and Mark it as a Solution if your porblem is Solved;))
(5,746 Views)
Hi
This vi is a sample I found in the forum. It actually has the same problem. Even if I set the grid style and colors to green I am not able to see it.
Anyone knows how to modify this vi to make the grid of x axis visible?
Thanks!
(5,732 Views)
Check this and let me know if it is working fine.. It works fine if you dont Autoscale the X axis.
Nitzz
(Give kudos to good Answers and Mark it as a Solution if your porblem is Solved:smileywink:)
(5,726 Views)
