waveform chart multiple columns
I am using a USB-6210 to collect 16 channels of analog data.  When I use a Waveform Chart to display the signals in realtime (Strip Chart mode) with the Stack plots option, there are 16 plots from top to bottom.  How can I set up the plots in 2 columns (ie, 8 plots in each column) without separating signals.  Thanks.
(3,384 Views)
I believe you mean Y Scale as column. In this case you can select the Plot > Y Scale to select in which Y scale the Plot data must be displayed.
(3,378 Views)
(3,323 Views)
Split the Array into two 8-element arrays and send them to different waveform charts.
(3,311 Views)
