waveform chart multiple plot
I'm having some problems plotting a multiple plot in a waveform chart.
The goal what I'm trying to achieve is 1) determining the difference between real and estimated data, which I want to 2) display in said waveform chart, seperately.
This all happens within a while-loop, which you can't see in below screenshot.
Right now all I'm getting is the difference of 1 object, instead of all objects who enter the for-loop. How do I adjust this?
Message 1 of 9
(12,998 Views)
Are you going for something like this?
Message 2 of 9
(12,980 Views)
Please do not post screen-shots, but post actual (editable, runnable) code.
I recommend you read the LabVIEW Help for Charts and Graphs.  From the fragment of code whose picture you showed, I don't think you understand how LabVIEW Charts work, and how you add points to the chart.  It is clearly explained in the LabVIEW Help.
Bob Schor
Message 3 of 9
(12,977 Views)
Yes, exactly like that.
Message 4 of 9
(12,965 Views)
Bob Schor
I really can't submit the full code, because it contains some code I don't wish to be publicly available.
Message 5 of 9
(12,959 Views)
One difference though, I only want to display the difference in values, for each 'object' that enters the for-loop. So for every iteration a new plot on the waveform.
Edit: see my very crude sketch, since I can't reproduce what I want. So every line represents the measured difference over time per object.
Message 6 of 9
(12,956 Views)
The chart keeps a history, so you do not have to maintain it yourself.  Just put your plot points into a Bundle like I show above and write directly to the chart terminal.
Message 7 of 9
(12,939 Views)
I tried this, but doesn't work. See attached image. I still get only 1 plot.
Message 8 of 9
(12,910 Views)
If you only have one numeric in your bundle, you're only going to have one plot. You're not building multiple plots by adding to that array, you're building an array of points on a single plot. This can all be learned from the Help file.
I would suggest switching to using a 2D array of data for your multiplot, to make it a little more intuitive:
I built the above Vi to match how you're already do it, but you can eliminate the shift registers by auto-indexing:
Cheers
Message 9 of 9
(12,895 Views)
