waveform chart, one plot, shows many
First off, I'm using LV7.0.  I'm passing data to a waveform chart.  The data is a one dimensional array converted to a cluster, then passed to the chart.  The chart properties are set to show only one plot, but there are so many plots on the chart I can't make heads or tails of it.  See attached.  Thanks for any help any of you could provide.
(3,515 Views)
hi
create a property node with History and clear the chart before plotting
N
(3,507 Views)
That didn't help.  The plot starts off blank, then fills from left to right with lots of plots at the same time, the begins to scroll.
(3,499 Views)
Accepted by topic author rickford66
What's the size of your cluster? That determines how many different plots you have.
(3,492 Views)
That fixed the problem.  I never had to mess with that before.  Thanks.
(3,489 Views)
