waveform chart shortcut menu problems
Hi Don,
"To make this work you have to switch off (disable) "default runtime shortcut menus" for the VI containing the chart."
"How do you get the reference to right-click menu at run-time if you have disabled the right-click menu?"
You only switch off the default runtime menu (in the VI options). That way you still get a menu reference - but the menu will by either your rtm (if no errors occurs) or empty (in error case as described in my thread). In my case I still had menu activation events as I only disabled default menus but not right-click menus at all...
Message 11 of 14
(1,015 Views)
Hi Don,
one more remark:
I talk about the second last entry of the VI properties "Customize Window appearance" dialog as described here...
Message 12 of 14
(1,012 Views)
Thanks, I think I can try implementing this now.
Appreciate your help.
Sincerely,
Don
Message 13 of 14
(1,009 Views)
Saving the run time menu with the control worked for me.
http://forums.ni.com/t5/LabVIEW/custom-shortcut-menu-not-showing/m-p/1890701/highlight/false
Dan Shangraw, P.E.
Message 14 of 14
(955 Views)
