waveform chart time scale changes using LabVIEW 2009
Underscore_c-
Our CAR system is not perfect and sometimes there are duplicate or very similar CARs.  The CAR that was fixed with the release of Patch F2 is CAR 183560, and that does resolve this problem.  I am running LabVIEW 2009 with the F2 patch installed.  I looked at the code you posted, and it runs fine as a VI.  Then I took that same code and built it into an exe.  Again, everything is working as expected.  After hitting the “stop” button, all the tick marks appear.  The way this code is written, the data and tick marks won’t appear until the “stop” button is pressed.  Did you restart your computer after installing the patch?  Your machine needs to reboot before the fixes will take effect.  Try this again as it worked correctly for me.
Mike S
NI AE
Message 11 of 13
(1,303 Views)
Are you Mike S or George P Burdell?
Message 12 of 13
(1,298 Views)
Mike,
I think there is some confusion. I'm not the original poster and I haven't uploaded any of my code. I have restarted the computer since the f2 patch was installed.
But I found the cause of my problem! If I disable the checkbox "Enable Enhanced DSC Run-Time support" under the build properties, my charts work normally.
  --David
Message 13 of 13
(1,283 Views)
