waveform chart x-axis screwed up
I have a goofy problem here with a waveform chart.  Originally, I had to set the font size and bold setting on this chart to 18 pt. bold.  I did so by double clicking on one of the numbers from each scale and changing that size and bold setting.  The entire scale changed to follow the change made.  Now, I have to change the numbers only to 14 pt, normal style.  As before, I double clicked a number on each of the y scales and changed the value, no problem.  The entire scale changed.  Not so with the x-scale.  When I try to do it with the x-scale, it reverts back to 18pt bold.  The labels are to stay 18pt bold.  Why is this graph acting screwy.  Did I accidentally lock it by changing some setting on it that I'm, not aware of?  See attached.
Thanks.
(3,099 Views)
When you select one of the x-axis numbers for resizing, make sure to select the space to the left and right  of the number as well. You can do this by triple-clicking the number rather than double-clicking it.
(3,091 Views)
Of course, that worked great.  Thanks!!
(3,085 Views)
