waveform distortion
I am using ni5640r to generate an array of signal and read it out from oscilloscope. Howevery, the waveform in the oscilloscope seems getting distortion. Can somebody help to find the reason?
Austin
Message 1 of 8
(4,514 Views)
Post your Code.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 2 of 8
(4,486 Views)
It would be helpful to give a little more information on your signal connections, generation rate, etc.  Something to initially check out though would be the probe compensation on your scope (adjust the compensating capacitor in the probe).  The document below shows how an overcompensated or undercompensated probe can affect a signal measurement.
http://zone.ni.com/devzone/cda/tut/p/id/4721
Also, I would recommend to post this question on the IF-RIO discussion forum also which can be found here:
http://forums.ni.com/ni/board?board.id=ifrio
Message Edited by Jordan F on 07-27-2009 11:47 AM
Jordan F
Message 3 of 8
(4,473 Views)
Also, what scope are you using?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 4 of 8
(4,439 Views)
Hi, everyone:
Thanks for your help.
I have tuned the capacitor on the probe. I don't think it has any problem.
I am using Tektronix MSO4104.
Austin
Message 5 of 8
(4,428 Views)
Hi Austin,
What is the type of probe you are using to connect the signals?  What is the generation rate you are using for the signal?  If you slow the generation rate do you still see the same type distortion?  Any detailed information on the setup would be helpful.
Jordan F
Message 6 of 8
(4,409 Views)
Almost every digital scope has a functions named Bandwidth limitation or something like it. If this function is activated it could perhaps cause your problem. It is a wild guess. But check it out. Also ensure you have original scope probes.
Hope it helps you out....
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 7 of 8
(4,402 Views)
Hi, Everyone:
I have reduced the generation rate already and also I have changed the bandwith on the scope, but seems no those problems.
I have posted my code, so may be somebody can help me to fix that error.  This problem has tracing me for a long time.
Austin
Message 8 of 8
(4,349 Views)
