waveform frequency control in LabVIEW
How does the waveform generation VI's in LabVIEW control the frequency in real time? I am trying to implement my own waveform generator (to output trapezoids) and need a way to control the frequency of the output.
Thanks.
(2,923 Views)
The freq can be controlled in a number of ways.
Use fixed output sample rate and modify output data.
Use fixed output data and vary output sample rate.
Use fixed data and control external voltage controlled freq generator.
Do any of these methods work for you?
Ben
(2,923 Views)
