waveform generation with Analog discovery 2 (Digilent)
I am new to LabView programming and doing a small project with an Analog Discovery 2 oscilloscope. My task is to generate some arbitrary signals and detect them with a graphical plot and modulate the signal also using QMH template. I have already worked something on it and am able to generate the signal and modulate it also.
My problem is with the " Detection" part; while running the program the detection part isn't working properly, that's why the generated signal is not showing. The problem I encountered was only while using the QMH template. without this template, I am not facing this problem.
Can anyone help me to figure out the problem where I need to make changes in the QMH template?
I have attached here both VI with & Without QMH template for your better understanding. I need your help, please
Message 1 of 1
(1,125 Views)
