waveform graph: how to insert a log in scale.multiplier
I would like to insert a scale multiplier in my waveform graph property node. The scale is a voltage, and I would like to do this operation:
new_scale_value = 10 * log ( old_scale_in_voltage).
This operation may create a new Y-scale in the waveform graph.
I tried a lot, but I cannot do this operation. Is exist a solution.
Thanks.
BD.
~ La programmeuse compile le C. ~
http://www.pmeonline.fr.st
http://www.nihon-fr.com
http://www.cinemasie.com
http://ippai.free.fr
(3,528 Views)
hi bdarroux,
apply u r formula to property node value of graph &  connect result to value of graph property in a event case,
here is a vi which will probabally solve u r problem
(3,521 Views)
Thanks, your solution is great, but, I have an other problem: my operation, sometimes, is not done, and the amplitude scale appears. This problem occurs 1 time / 5. What's wrong with my code?
BD.
(3,514 Views)
hi,
can u post u r code, so that i can look at & get u solution
Regards
ak
(3,496 Views)
Sorry, I solve by myself the problem, it was just a long loop which brakes the program... 😉
THanks for your help.
BD.
(3,492 Views)
