waveform graph( time (s)), (continuous simple)
Good morning
I am doing the acquisition continuously, and I want to trace the data after the end of the acquisition for this I used append waveforme vi; the problem is that I don't understand the scale of the X, I want to plot it as a function of time in seconds?
how can I do this
here is the vi attached
Thanks in advance
(1,272 Views)
Hi Amelie,
Your graph is configured to ignore waveform timestamp: what does it show after running your VI?
What exactly don't you understand?
(1,266 Views)
hi ;
I thank you for your feedback
the scale of X is between 0 and 1 I don't understand where that comes from,
when I disable ingore wavefrome timestamp nothing is displayed, and the time scale is from 1904
I only want to trace as a function of time in seconds(on the scale of x I want to have time in seconde)
(1,240 Views)
Hi Amelie,
you fail in providing useful data, not even images of data…
Can you run your VI, end as usual and use edit->set all as default. Then save your VI and attach again…
(1,232 Views)
