waveform graph update mode
Is there a way to plot data continuously in waveform graph similar to a waveform chart?
I do continuous data acquisition and I need to use cursors on the plotted results so I use a waveform graph. The problem is that the graph is refreshed all the time and shows only the new results. I tried to get the complete data stream plotted by putting the data acq block into a for loop, enabling the indexing and storing the acquired/indexed data blocks in an array [See attached picture]. It still keeps refreshing.
Any ideas and hints are welcome.
Krivan
(8,747 Views)
Is this what you want?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(8,718 Views)
I tried your code and it did work. I implemented your suggestion but in my application it keeps adding the new data as an additional curve. I cannot append the new data, even if the shift register feeds the data into the build array. I can't see at the moment what I did wrong...
(8,701 Views)
Accepted by topic author krivan
Have a look at this image
Gaurav k
CLD Certified !!!!!
(8,693 Views)
True. You're right. Thanks!
(8,682 Views)
