waveform graph x scrollbar in LV7.0?
LV7.0.   Why does the Waveform Graph have a Show Scrollbar property if the scrollbar is not active?
Thanks.
Message 1 of 11
(3,816 Views)
Because the property is member of the Waveform Graph class and you are seeing it at edit time. It has no idea if you're using a scrollbar or not.
CTA, CLA, MTFBWY
Message 2 of 11
(3,808 Views)
I'd like to use a scrollbar.  I'm using the waveform graph to display already collected data.  I'm allowing the user to rescale the time axis (x-axis) and if they zoom in on the graph, I'd like to give them the abilitiy to scroll the graph too.  Is there a way to enable the scroll control?  Thanks.
Message 3 of 11
(3,806 Views)
If you set the property to 'true' does the scrollbar appear?
CTA, CLA, MTFBWY
Message 4 of 11
(3,804 Views)
It appears but I can't use it.
Message 5 of 11
(3,802 Views)
I'm not seeing that in the latest version so it may be specific to 7.0
CTA, CLA, MTFBWY
Message 6 of 11
(3,800 Views)
I was hoping to get 2 versions of this code, one in 7.0 and the other in 2010, but looks like it's going to be a huge hassle.  I opened it with 2010 and I still get the same behavior.  Scrollbar shows, but does not work.
Message 7 of 11
(3,796 Views)
Did you enable the x scrollbar by doing this or with the code?
CTA, CLA, MTFBWY
Message 8 of 11
(3,794 Views)
As your picture shows... let me guess, that's the wrong way.  haha
Message 9 of 11
(3,790 Views)
No, it's the correct way 🙂
Are you zooming in on the x axis like this? You also need to have data on the plot in order for the control to be active...
CTA, CLA, MTFBWY
Message 10 of 11
(3,786 Views)
