waveform updated during measurement
Hello, I have attached a file from the VI examples, the VI is a 2-channels sweep for FET characterization. I see the plot is generated at the end of the data acquisition.
Is there a way to see the plot updated in real time? so that every point is plotted during acquisition? Thank you for your support...
G.
(2,847 Views)
Just maintain the XY arrays in a shift register.
(2,812 Views)
Dear crossrulz, thank you for your suggestion. I failed to try this way because the library niDCPower Measure Multiple.vi looks like to collect all the data and send them outside the for-loop at the end of the collection, so I cannot find the shift register terminal to link to...
(2,777 Views)
Accepted by topic author GT_
Move the graph INSIDE the loop.  And build the array and maintain in a shift register.  There is no shift register in there to add to.  You need to create it yourself!
(2,769 Views)
Ok, it works at the end 🙂
thank you!
(2,755 Views)
