waveform
Hello there!
I am currently working on our VI. What I want is to plot the data in a waveform from the scan from string. However, it doesn't plot the data properly. I am currently working on 2 ways on how to do this. Any suggestions? thank youSmiley Happy
(4,332 Views)
Define "not working properly". Are you expecting a graph over time? If so, you want a waveform chart, not a waveform graph.
In terms of you code, is the device supposed to continuosly send information, or only when you send the "A"? If it's continuous, then I can see why you'd have the VISA Read where you have it. However, if it's only when you send the "A", then it should be inside the case structure.
(4,325 Views)
It does not graph the data received. It would receive an information every 30 mins. It must graph or plot the info 🙂
(4,320 Views)
(4,320 Views)
What kind of debugging have you done? Have you put a probe on the output of VISA Read to verify you are actually receiving the string you expect? Have you put a probe on the output of the Scan From String? Have you put a probe on the wire going to the graph?
(4,303 Views)
