waveforms over datascoket
Is it possible to write waveforms over datasocket and convert it back to waveform on the other side?
that is without having to deal with additional conversions to string or array formats.
Sam
(3,710 Views)
Help for datasocket write says this for the data input "data can be in any format or LabVIEW data type."
(3,704 Views)
But I don't seem to be able to convert a variant directly to a waveform after a read!
(3,704 Views)
All you have to do is wire a waveform control to the type input of the DataSocket Read function. Here's the shipping example called DS Reader modified to get a waveform data type.
(3,697 Views)
I don't think you need to be using the variant function. The waveform should wire directly into the datasocket write.
(3,689 Views)
I have a waveform wired to ds write. I can see the data with ds read as variant, but if a waveform type is the input for ds read, as suggested, nothing comes through. this is not a major problem, but puzzling none the less!
Sam
(3,680 Views)
I'm not sure what your problem could be. Why don't you post your DS reader and writer VIs so someone can look at them.
(3,667 Views)
