wavefrom comparing
 my application is to check the PCB i/o pins... first i have to corresponding signal to every pin in GOOD PCB board and the output of each pin should saved in excel with the help of write to spreadsheet.. then the database be act as master for other PCB boards..
If i wanna check the other pcb board means the same corresponding signals should be send to the each pin of the PCB board.. the Output received from the board should check with the data already saved in the database if it is match's means Status LED should Glow otherwise its not to glow...
pls help me to finish this application.. i have attach model vi with post and excel too....
N. Srinivasan
(4,433 Views)
See i have to send a signal (simulate signal) to the PCB board (GOOD PCB BOARD FIRST)  to get the output signal from the board.. and its should save in the excel sheet.... (For example first the customer will give good Pcb board to me) i have to note all the signal received from the board wrt input signal.. its cos further they'll priovide the faulty PCB BOARD to check  the board whether its having error in it...
In the last Post i have attached only the method of my Program...
my doubt is if all the received signal are saved in the excel sheet first.. then  when im going to checking faulty Pcb board with its received signal i have to compare this received signal with data save in the database(pin 0 - sine signal input and output is may be sine wave)...
(ex: PCB board will have 40 pin each pin will have diff signal and corresponding output should to be verify..)
N. Srinivasan
(4,430 Views)
Actually in my program i have two part that is 1. Learning and 2. Comparing
LEARNING:smileysad:GOOD PCB  BOARD WITH 25 PINS)
 A. I have to send the signal each and every pin in the board
 b. secondly i have received the o/p signal from board and save in excel sheet it'll act as like MAIN DATABASE...
 c. Suppose for the pin 0 input signal is sine wave means o/p signal from that pin may be sine wave(just consisder0
 d. This MAIN DATABASE should not to disturb after received o/p from the Board.
NOW I HAVE ATTACHED THE  PROGRAM WITH ONLY ONE SIGNAL i.e., SINE WAVE...
COMPARING:smileysad:FAULTY PCB BOARD)
a.  Same steps should be follows here
b. but instead saving the o/p received signal in a database we have to compare the received signal with
   the MAIN DATABASE SIGNAL...
c. if both data match the status should be in HIGH otherwise it should be in low condition
    HIGH ---- means its matched
    LOW ----- means its not matched....
my problem is that  i have the sine wave signal data in the excel (DATABASE) and then i should call the data base and should  compare with the received signal...i HAve same sinewave for input and comparing the another sine wave(i.e., SIMULATE SINE SIGNAL) the status giving its not match???
N. Srinivasan
(4,429 Views)
can u send any program related to comparing like my program(i.e reading from text file with multi signal data and comparing with real time signal )... pls if u send it to me means it'll help me more... im new for this dicussion form i dont know to establish my question clearly.. dont mistake me..
Anybody help me to complete my program and my problem  too...:smileysad:
N. Srinivasan
(4,428 Views)
Anybody is thr... i need help from u.... clear my doubt im beginner in labview....  how to compare the data in exccel sheet data with the real time data in labview.. help me pls.....
N. Srinivasan
(4,402 Views)
Don't start a new thread when you already have a discussion going on in another one.  Keep the conversation in the original thread.
Also, please use your entire keyboard when typing messages.  Don't use text message abbreviations.
Message Edited by Ravens Fan on 10-11-2009 12:39 PM
(4,396 Views)
ok ..... i'll use my keyboard.....
still my doubt is not cleared... anyone can help me.......???????????
N. Srinivasan
(4,377 Views)
