wavelet transform
Hi,everyone. I meet a problem that has confused me for almost one month. I use the VI from Signal Toolkit to detect the ridges of the wavelet transform of a signal.But I can't reconstruct the signal using the ridges. Could anyone help me?
Message 1 of 10
(5,202 Views)
Message 2 of 10
(5,188 Views)
Message 3 of 10
(5,187 Views)
I am using LabVIEW8.5 with Signal Toolkit7.0 and I can't find suitable VI to solve my problems.
Message 4 of 10
(5,175 Views)
Use the Wavelet Analysis VIs to perform transforms and inverse transforms between a signal and the wavelet coefficients of the signal. You can use the Feature Extraction VIs to perform denoising, detrending, probability density function estimation, peak detection, edge detection, and ridge detection on a 1D or 2D signal.
I am sure you have it in 8.6 not sure in 8.5,
Message 5 of 10
(5,171 Views)
At first, thanks for your enthusiasm in my topic. LabVIEW8.5 possesses functions as you have mentioned, while my problem is how to reconstruct the signal using the ridges detected already.
Message 6 of 10
(5,159 Views)
See whetherthis
or this will help
Message 7 of 10
(5,137 Views)
It is very kind of you to do so much. I really appreciate your help. I will try my best to solve it.
Message 8 of 10
(5,131 Views)
Please do update and post back if you are stuck
Message 9 of 10
(5,129 Views)
In the paper written by Jing Lin, I just find there are so many technical terms that make understanding almost impossible. I have bought a book named 'An Introduction to Wavelet' by Charles K. Chui. It is necessary to get enough basic knowledge before making any progresses.
Message 10 of 10
(5,080 Views)
