wavlength usb4000
I have a usb4000 oceanoptics spectrometer and would like to extract a spectrum of intensity vs wavelength. However upon outputting the spectrum data to a text file I do not see a wavelength or x axis column with the values as I would see in the usb4000 default software which gives me a text file with the x axis ( wavelength) values in one column and the light intensity (y axis) in a second column.
Anyone know why this may be?
P.S- If I am being unhelpfully vague and/or you need more details please let me know!
Thanks!
Message 1 of 10
(3,417 Views)
Hi
Never mind problem solved! Maybe I deserve a Kudos 😉
Message 2 of 10
(3,384 Views)
I'm using Waveform Chart and I have Time (x-axis) and Amplitude (y-axis). Do you know how to convert my x-axis to Wavelength and y-axis to Absorbance/Intensity/Concentration? If you have a link please send me one.
=_)
Message 3 of 10
(3,343 Views)
@AKCanada wrote:
Hi
Not until you document your answer here in the Forums.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 4 of 10
(3,339 Views)
Hey, I would need a little more information. Do you think you could post a screen shot of your program please?
Message 5 of 10
(3,337 Views)
Are you able to see the attached screen shot?
The axis on "Waveform Chart 2" I have currently are Time (x-axis) and Amplitude (y-axis)
Are you able to convert those axis into wavelength and absorbance/intensity/concentration?
If you can send me a link, that would be very helpful
=_)
Edit: Also, are you able to reset the x-axis for each run, as you can see my Time axis starts at 5690779. I would like it to reset back to 0.
Message 6 of 10
(3,334 Views)
If my previous queston was a little hard. Perhaps someone could help me explain how to convert from "Spectrum by Pixels" to "Wavelength"?
I have a guess it has something to do with 2*pi, frequency and period?
Message 7 of 10
(3,322 Views)
Thanks for attaching that screenshot! There is another labview vi called read spectral waveform. It is included in the downloadable labview instrument driver. If you output to a graph from there you should get intensity by wavelength. If you have any questions please let me know!
Message 8 of 10
(3,316 Views)
I will try that now, the last time I tried it gave me some sort of error.
I'll try and get it working
=_)
Message 9 of 10
(3,314 Views)
Thank you, it works perfectly 😃
Now I can work peacefully
Thanks a lot !
=_)
Message 10 of 10
(3,305 Views)
