we have PC-LPM-16 card installed our DOS based opearting system we want to windo
Hello
We have PC-LPM-16 card installed in our system. this system if for checking online oil content of POY bobbin.
it is DOS operating. as this card is absolute now and upgraded version is available. but this upgraded card support windows system
so we require to upgraded our system to graphical user (labview) and synchronise with server
Can you help us?
Hiren Popat
Dy. Manager-Automation
Rajashree Polyfil
9726868818
(2,696 Views)
Hello Mr. Hiren,
The upgraded version of PC-LPM-16PnP can be used with Windows. You can create a program for your operation i.e. checking online oil content of POY bobbin, using LabVIEW installed upon your Windows computer with proper NI-DAQ drivers supporting your board(PC-LPM-16PnP).
The PC-LPM-16PnP is a legacy(relatively old) device and might not be compatible with all versions of Windows. It requires a set of drivers called NI-DAQ for interacting with your windows PC. The specific drivers can be downloaded for free from our website. The following link shows you the drivers required for your board depending upon the compatible operating system  http://zone.ni.com/devzone/cda/tut/p/id/6918
For purchasing a licensed copy of LabVIEW, you can contact NI at:
Tel: 91 80-4119 0000
Fax: 91 80-4119 0010
Sumit Sen
(2,676 Views)
Hi Hiren Popat,
        I am looking for the card that you are trying to replace. Can I purchase it from you?
Best Regards,
Paul H
(805) 968-2001
(2,595 Views)
Paul:
Just in case he does not, here is another potential source to purchase from:
http://www.artisan-scientific.com/62408.htm
-Ak2DM
(2,578 Views)
