web cam continously acquire image, how do i scan bar code?
Hi, I am working on this project,
I am using a webcam to scan a barcode.
I got the webcam to continously acquire images and record them to avi.
but I am having this problem...how do i use the images from the webcam use VISION barcode to decode the barcode?
i have created this project, but i am facing this error. can someone tell me where i did wrong and how to fix it?
thank you in advance..
(3,925 Views)
There are a lot of great example programs on Developer Zone for decoding and working with barcodes.  What specifically are you having trouble with on your applications?
Thanks!
Meghan
Message Edited by Meghan R on 04-05-2009 10:36 PM
(3,891 Views)
sorry about late reply...i was trying to do it on my own and I just can't seem to get the barcode portion of my code to decode properly.
can you take a look and see what advice you can give me to fix it?
(3,849 Views)
I will look into your code to see if there are any major issues, but I really do recommend taking a look at examples.  At the very least, it's good to learn different ways you can implement.
Thanks!
Meghan
(3,826 Views)
Can you tell me what exactly is the error that you're seeing?  What's not working properly? Also, your LLB does not include everything in your code, there are some controls/subVIs missing.
Meghan
(3,814 Views)
