web camera don't work in the Russian Win XP
Hello all
I have LV 7.1 and I have Win XP - English and Russian version
In English version Win XP  I receive image from WEB-Camera.
In Russian version Win XP  I receive the ERROR
What do I do?
Best regards
Iskander
(3,337 Views)
Hey Iskander,
Check out the following link that talks about different OS Support for the NI-IMAQ for USB Cameras driver: https://forums.ni.com/t5/LabVIEW/USB-DRIVER-FOR-IMAQ/m-p/294872/page/3?view=by_date_ascending.
On page 3 of this long DF thread, it talks about how the Russian version works with the version 1.1 an higher. Currently (at the time of this post) the most recent version of the NI-IMAQ for USB Cameras does support the Russian OS.
I hope this helps. If the newest version does not help, then you might want to post a comment on that other DF thread.
DJ L.
(3,328 Views)
Hello DJ L.
I have changed the file.
All work
Thanks for the help
Regards
Iskander
(3,317 Views)
Hello DJ L.
I have another problem
My PC has two Win XP and two LV8.0
On the my PC I installed WEB camera and change the files  on every Win XP
 But I received the image from WEB camera only first  Win XP on the second Win XP I received the ERROR System WEB Init
http://forums.ni.com/ni/board/message?board.id=170&message.id=277467&view=by_date_ascending&page=1here
What do I do Regards
Message Edited by Iskander on 10-17-2007 02:50 AM
(3,204 Views)
Hi Iskander,
My guess is that the XP machine that you are currently having trouble with is the Russian version while the working program is English.  Here is the link where poster "Brad" attaches the DLL that you need to replace in order for the Russian XP SP2 to work properly.  I believe about half-way down Brad posts the file and the next post is from a user who is now successfully using the IMAQ for USB driver in Russian.
http://forums.ni.com/ni/board/message?board.id=170&message.id=154541&view=by_date_ascending&page=3
The error you are seeing is most usually associated with using the IMAQ for USB driver in a non-English system.  Hope this helps out!
Carlton
CLA
(3,173 Views)
Dear Carlton H.
Thanks for the Help
All work
Regards
Iskander
(3,122 Views)
